sigma phase detection in super duplex tubes
Is it possible to check the sigma & intermetallic phases in super-duplex tubes using online ultrasonic testing equipment and if yes what is the minimum requirement for the testing machines?
RE: sigma phase detection in super duplex tubes
http://www.welding-advisers.com/
Steve Jones
http://www.pdo.co.om/pdo/
If it is a real concern you can sacrifice a tube.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
