catia process
catia process
I have a question. For example I'm executing a macro in batch modus with Catia but if I don't get any CATIA license to execute that the process will still remain there for hours.How can I solve that without searching for the process and killing it.
Do you have any suggestions?
RE: catia process
Assuming you're running XP. I shouldn't assume, but you didn't specify...
Check out CATBlog!
RE: catia process
I had this happen one moring when our licensing server was down. I was just starting up CATIA normaly. No error messages splash screen or anything. I would contact the company that provides you techincal support and describe the exact bug conditions so they can pass it on (if they are intrested.)
