Locating Walls in a new building
I've heard that:
"walls should not be located along the building's main column lines"
Can someone tell me why?
d6.
RE: Locating Walls in a new building
If you have CMU walls partially bracing columns you will end up with a stiffer element than anticipated, thus attracting higher lateral loads to the column that may lead to a shear failure.
AUCE98
