HYSYS and CO2 Freeze
I have recently been having issues with the CO2 freeze utility in HYSYS. One of the more interesting things I've noticed is that the predicted CO2 freeze-out temperature for liquid hydrocarbons is extremely pressure dependent. For example:
For a liquid with the following composition.
CO2: 4.1%
C1: 87.4%
C2: 8.3%
at 365 psia
CO2 Freeze is -154.82F
at 321 psia
CO2Freeze is -138.01F
Shouldn't the liquid-solid equilibrium be fairly independent of pressure?
There is also a big drop-off in the CO2 freeze temperature around 321 psi, but I've already complained about the discontinuity to their technical support staff several months ago. I haven't received much feedback, so I've given up on them for now.
CO2: 4.1%
C1: 87.4%
C2: 8.3%
at 365 psia
at 321 psia
RE: HYSYS and CO2 Freeze
I believe they market a utility with better results. I looked into this but felt it was not worth it...after reading the paper I am more comfortable with the discrepanices in the HYSYS software.
