Sorting combinations of letters and numbers
I have a list I want to sort in the following way:
original
200
102A
300A
305B
100
101
WANT
100
101
102A
200
300A
305B
unfortunately excel likes to sort all numbers first and all letters second.  So I get the following undesired result:
EXCEL'S RESULT
100
101
200
102A
300A
305B
Any Ideas?
RE: Sorting combinations of letters and numbers
Remove the letter, if occurs, by using the LEN, RIGHT, and/or  LEFT functions (I don't know if you always have 3-digits of numbers, so can't say exactly which function will work best).
See Thread 770-131895, sort the numbers list. Do a second sort of the letters "suffix", and use CONCATENATE to restore the letter "suffix" to the numerical portion.
Thank you SacreBleu.  However, that thread is on the automatic sorting of NUMBERED lists only.
My problem is that I need to sort both Numbers and Numbers+letters in a way that is not Excel's default way.
One way but tedious :
In an adajacent column use =""&A1 for each row.
Range Value the new column
Now sort new column and when asked select option sort numbers and numbers stored as text separately.
Ok found a solution that is not elligant, but works.  I found the solution on the follow web site under "Sorting mixed numbers and alpha, numeric prefix (#mixed)"
http://www.mvps.org/dmcritchie/excel/sorting.htm
Only I made a quick formula rather than their CellValue formula.
=IF(B2="",A2,VALUE(LEFT(A2,3)))
Where column 'A' is my values, 'B' is my dummy row for sorting.  Then I just do a multiple sort with column B first and A second.
