Chemical Injection
Chemical Injection
Chemical Injection
I'm looking for manufacturers of chemical injectors (using venturi).
I've found many for agriculture or soap (car-wash) applications, but I'm looking for a more industrial type.  This would be low pressure, low flow (1-2gpm).
This will be used to 'suck' Methanol from a drum into a water pipe.  Also looking for this to be UL approved/listed....something I haven't seen in the above applications.
Any ideas on manufacturers out there?
RE: Chemical Injection
Here is a  supplier of equipment to inject and mix.  We used components from both companies in materials over a wide range of viscosities.  The company has very good technical support. You need to give them a call.
http://www.s-k.com/index.htm
