sizing the neutral conductor on 120/240V services
What factors should be considered when sizing the neutral conductor on a single phase 120/240V service? A lot of utilities use a reduced neutral (ie Aluminum 4/0 for the two hot legs and a 2/0 neutral), but I understand harmonics from electronics can require a neutral at least as large as the hot legs. Anyone have any comments on this?
K2ofKeyLargo
RE: sizing the neutral conductor on 120/240V services
#2AL, 1/0 AL, and 4/0 AL. The 120/240 volts does not have as much problem with harmonics because the hot legs are 180 degree out of phase and the triplen harmonics cancel.
WRT harmonics, as already pointed out, the triplens DO cancel.
So if the phase wires are 1/0, the neutral will be #2. If the phase wires are 3/0, the neutral will be 1/0.
After the utility/facility demarcation, the NEC or CEC (or OESC) applies.
