Sub-assembly of a assembly
I made a sub-assembly of assembly, in the sub it is rotated to the accordinates 180 degrees.  How can I keep this from happening and fix what is already rotated?
RE: Sub-assembly of a assembly
It sounds like your subassembly is oriented 180 degrees off from your assembly.  You'll need to build your assemblies in the same way to get automatic alignment.
You could rotate and mate your subassembly in your assembly and not worry about it.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
