Adding centerline as reference in drawing
Is there somewhere I get the annitation for centerline reference in a drawing?  CL
RE: Adding centerline as reference in drawing
Feature Manager Tree - Text Format - 3RD button on right. or
Feature Manager Tree - Dimension Text - 4th button 3rd row
Where would I find this.  Do I need a special add in?
You mean just adding a centerline to a drawing view?
Insert/Annotations/Centerline
or
Drawing the line in and use the line format toolbar or a layer to make it the centerline linetype.
Jason
Insert note > text format > add symbol.
Flores
Are you looking for just the CL annotation to show at the end of a centerline?
Per ASME, CL is not needed anymore anyway.
But if you are looking for it, see smcadman's suggestion.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
