Create Layer Category
Is there a program out there to create Layer categories in whole without doing one by one?
For example:
1-15 Solid Geometry
16-20 Linked Objects
21-40 Sketches
41-60 Curves
61-80 Datums
81-100 Sheets etc....
RE: Create Layer Category
You can select multiple layers to include as a group. Also, perhaps consider saving an empty part file with these changes (and any other required options) to open as a startup part file.
Bill
A simple grip program could also do the trick.
Thanks cowski,
Where can I get a grip for this?
aaahhhh...therein lies the REAL question.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Have you tried doing this with a macro. Then use the macro to create the categories in parts that do not have them set up. That might help others create the categories too in case you don't use a start part as wmalan suggested.
you can use the following keyboard shortcuts.
ctrl+shift+r Record macro
ctrl+shift+p Play macro
Michael
You either need to learn and write your own GRIP program OR find someone to do it for you for free or a price.
What is a program like this worth to you and your company?
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Geo,
   As an added thought or something to consider... Is it intended for the 'model' and 'drawing' layering categories to be the same?  The company I work for have seperate layering strategies and standards for each.  Do you want the ability to add or modify the layers on the fly, or simply a 'standard' layering convention to use for a particular customer?
   Might I suggest supplying a complete list of layering categories (along with their respective layers) for both drawings and models, and perhaps the grip god will induce a bored code slinger with the inspiration to help you out.  A list of the platforms used by your company would also be helpful (unix, windoze, etc.) since they have to be compiled on the machine platform they will be run on.  =)
SS
This one is really simple, if you have a grip license you can compile and run it. It doesn't do any error checking, but it would not be difficult to add.
CODE
$$ PROGRAM PURPOSE: CREATE DEFAULT LAYER CATEGORIES
$$ DESCRIPTION
$$ 9-07-2005
$$ SUBROUTINES USED: NONE
$$CAT/'name'[,layer list][,CAT,'cat list'][,DESCR,'description'][,IFERR,label:]
CAT/'SOLID_GEOMETRY',1..15
CAT/'LINKED_OBJECTS',16..20
CAT/'SKETCHES',21..40
CAT/'CURVES',41..60
CAT/'DATUMS',61..80
CAT/'SHEETS',81..100
HALT
Our company has done this with a macro, it's propbably the easiest way if you aren't familiar with program writing. Or if you do not have grip.
