Yellow Text
Yellow Text
When I export drawings into the ".dwg" format, and open these drawings with AutoCAD, the text and dimensions are yellow. This causes problems with my vendors. If they print the drawings, the yellow text is too light to read. If they try to change the color, the dimensions change (style and locations). How can I export drawings so that the text and dimensions are black, or some other color? Thanks, WDG
RE: Yellow Text
OR
My personal preference is to create a 300dpi full scale PDF of my drawings (probably because I developed my own method for doing so). I submitted the process and files required to a company called truEinnovations, and they posted it to their knowledge base. You can find the process and required files here:
http://www.trueinnovations.com/support/kbase/selection.asp?id=100061
It creates a 'one-click' solution for creating the PDF files - pretty convenient...small file size, accurate resolution, accessible by anyone (free Acrobat Reader download), and prints out a sheet whose quality rivals a ProE plot.
Recneps
RE: Yellow Text
RE: Yellow Text
So warm up that keyboard and submit enhancement requests like there is no tomorrow!
Recneps
RE: Yellow Text
I fixed the problem by changing the colours in Autocad.
there is no need to explode, that creates big problems
Using the 'change'
select 'all'
select 'change properties'
select 'change colours'
change the colour to 'w' for white
this will print black lines on a white background
RE: Yellow Text
RE: Yellow Text
Before exporting the ProE drawing, use Utilities>Colors>System to bring up the system colors dialog. Click on Scheme at top of window and select Black on White - this loads a color scheme that will export black entities on a white background. Select Scheme>Default to get your colors back afterward.
Recneps
RE: Yellow Text
Here is a trick that I discovered in AutoCAD: Using TOOLS>WIZARDS>ADD COLOR-DEPENDENT STYLE TABLE, Select “Start from scratch”, give it a name (“noyellow”), Select both options, then select “Plot Style Table Editor”. In “Plot Styles” box, select the color yellow, in the “Properties” “Color” box, change the “use object color” to “Black”. “Save and Close” and “Finish”. Although the screen still shows yellow dimension, it converts them to black when it prints.
RE: Yellow Text
The file "dxf_export.pro" must be placed in the current working directory when the export to .DWG is performed. More details about line color when exporting to DWG can be found at ptc.com.
1. Create a text file named dxf_export.pro
2. type 'map_color' (space) pro/e color name (space) AutoCad color number.
Example dxf_export.pro file:
map_color BACKGROUND_COLOR 0
map_color DIMMED_COLOR 4
map_color LETTER_COLOR 1
map_color HIGHLIGHT_COLOR 1
map_color EDGE_HIGHLIGHT_COLOR 5
map_color GEOMETRY_COLOR 2
map_color HIDDEN_COLOR 3
map_color SHEETMETAL_COLOR 3
map_color CURVE_COLOR 2
map_color VOLUME_COLOR 2
map_color SECTION_COLOR 4
(For a list of Pro/E color names - modify the linestyle of a sketched entity on a drawing)
FYI: Pro/E entities may not correlate with AutoCad entities with regards to color. Pro/E object lines are one color where (my company) we use several colors in AutoCad.
RE: Yellow Text
Pro/E 2001: copy and edit the file '%proe_loadpoint%\text\intf_configs\dxf_export.pro' (replace %pro_loadpoint% with the folder path where you installed Pro/E.)
This file includes everything needed to format a DXF or DWG exported file from Pro/E. I am sure you will find a similar path in previous releases of Pro/E.
Have fun!
RE: Yellow Text
I have yellow display text but it will print black.
Where does this feature live. Display one color print another.
-Caper-
RE: Yellow Text
Good morning Casper! I think you'd better have another cup of coffeee and read the thread again.
Don
BCF Technology
Mohawk Industries
RE: Yellow Text
Don
BCF Technology
Mohawk Industries
