Weldment cut lists: show balooned only?
I've been making drawings of weldment parts by using the relative view function.  The problem is, I need a cut list on the drawing for each individual part to show only the definition for that part.  Every time I try to insert a cut list, I get info about all the members in the weldment.  Is there a way to insert only the one line of the cut list that refers to the member shown?
RE: Weldment cut lists: show balooned only?
If you dimension the relative views, a cut list is unecesary.
It's like having a BOM for a single part.
But if you really need it, the only way I know of is to Split the table above & below the item you want and move the unwanted sections outside of the drawing borders.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Thanks for the help, I'll try this out.
