Bonding PTFE to EPDM
I am designing a product which will be using a diaphragm. It needs to be PTFE coated EPDM. The supplier sent back samples bonded with an acrylic-based double-coated film. These diaphragms peeled right apart. I believe there is a better way to bond PTFE to EPDM. I have heard that the best way is to burnish the PTFE surface with a primer and then bond using a cyanoacryate gel. But this is just one idea. What do ya'll think? And can you recommend some product?
RE: Bonding PTFE to EPDM
You have to work with the adhesive suppliers to find out which adhesive will work the best with each system.
http://www.ptiwebsite.com/index.cfm/ac/home
http://www.abbetch.com/about.htm
Why do you need Teflon?
