Folder Names,putting them in order
When you make new Windows folders, use either upper or lower case for the first letter. If you mix the case, then Pro/E sorts folders by upper case first, then by lower case.
So you get;
D:/Projects/...
 ABC1
 ABC2
 ABC3
 abc
 abc-1
Steve
http://www.sprdesign.com
http://www.3dlogix.com
RE: Folder Names,putting them in order
Hi 3dlogix,
We used to a similar thing pre Intralink, but we used 1-abc, 2-abc 3-ABC, then case did not matter.
Tofflemire
