contolling two booster pump stations in serie
do you have any ideas on how to control two booster pump stations some distance from each other?
RE: contolling two booster pump stations in serie
Some places have used radio frequency controllers - it depends on what you are trying to control.
Most boosters are either ON or OFF unless you're installing VFD's to adjust speed. The problem with variable speed is the time lag due to line length - this is typically adjusted based on testing - or instrumented and handled back at the control room via hard wire or radio control.
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut."
-- by Albert Einstein
thks sprintcar
what is the important criteria?
should the two flow rates of the two pump stations balanced, what else?
