Pump alignment with Coulping installed?
Hi all,
When performing laser alignment must the coupling be removed?
I’ve witnessed a millwright/mechanical fitter performing an alignment check on a pump with the coupling installed, however the coupling bolts are loose.
Will this not prestress the alignment? REMOVE COULPING !!
Cheers in advance.
Cheers in advance.
RE: Pump alignment with Coulping installed?
