Opening a workbook at a specific worksheet
G'day,
I need to open a workbook at a specific sheet each time but don't want the hassle of making sure I return to the face sheet and save the file before I close it.
Is there any format such as:  filename, sheetname
that I can use?
regards
SC
RE: Opening a workbook at a specific worksheet
Don't think so, but you could modify the AutoOpen macro to select the sheet you want
TTFN
Why not write a macro that does the switch to sheet and save together so that way you will have it open on the sheet you want when you re-open?
Best regards,
Matthew Ian Loew
