WASTE WATER FLOW METER
  WHAT YOU RECOMAND TO WASTE WATER FLOW METER ?
  WE HAVE WASTE WATER TREATMENT STATION WITH DISCONTINOUS FUNCTION. THE FLOW CAPACITY OF THE STATION IS ABOUT 150 CUBICMETERS/DAY AND THE MAXIMUM FLOW CAPACITY OF THE PUMP IS ABOUT 5 CUBICMETERS/HOUR. WE CAN PUT THE FOW METER TO A PLASTIC TUBE(PVC)  WHITH 100 MILIMETERS EXTERIOR DIAMETER.
   THANK YOU,
   DAN VIO
RE: WASTE WATER FLOW METER
Transit time ultrasonic flow meters are not invasive and can be clamped on. I would prefer to use a mag flowmeter. See Endress & Hauser, Krohne, ABB or Invensys for a suitable device.
