young modulus aluminium
is there a web site where i can find the young modulus of aluminium
thanks in advance
cees
thanks in advance
cees
RE: young modulus aluminium
Wes C.
example 7075 t7351 and 7075 O and 7075t6 and so on
this for calc in software
hope some can still help me
i only get about figure's in a group but i need specific of each sort
klaas
http://w
with aluminum alloys that also diffentiated some
of the properties by different cross sectional
areas.
Steven Fahey, CET
http://w
altough is a very interesting document and handbook
there is still no young modulus
also i need specific 7075 t7351
if you look at other properties on 7075 T6 its differant
shear and strenght
if you look at matweb
so i cannot assume all 7075 are the same
so who can help me?
I am curious what you are designing that requires such accuracy in the Young’s Modulus that you can’t make the assumption. Rarely do I have the opportunity to work on a project that has the manufacturing tolerances, the applied loads, material tolerance, etc. so well defined that a 5% uncertainty in any of the material properties significantly impacts the design. If you assume the worst case for the Young’s Modulus, will it significantly impact your design?
And, if you do find a specific reference for the Young’s Modulus for 7075 t7351, how are you going to determine the accuracy of the data regarding your specific piece of metal that will end up being used for your design?
good luck.
Wes C.
i design a composiet bike
complete under 4 kg
must be endure 250.000 cycles of 1500 n/m
so every part is to its limit's
and of course we make and design evry part our selve
for other reasons 7075 t6 is not a option
and for other reasons every part must have aerospace certfied material
not unsurprising much like the other varities of 7075
good luck, it's going to be difficult to make an efficient bike out of 7075 (not particularly weight efficient, not particularly strong in fatigue, difficult to weld, ...)
i do not make the complete bike out of a 7075 t7351
only some parts but still its going to the limit
and the bike must be the stiffest avaible on the market
frame gone be mainly out of carbon
Is this a bike in competition to be sent to mars?
Wes C.
but i have looked at the page 373 in that handbook at chapter 3 3.2.3 =2024
but its about 2024
meaby i am wrong sorry for that
but i see no where stated 7075 T7351
sec 3.7.6
if you are looking at the pdf version look on page 675 of 1728
Wes C.
