Transfer fans usage in commercial bldg
I am reviewing a project design that utilizes a transfer fan. It will be located in ceiling of one office room and using grills and ducts, transfer cooler air into a conference room adjacent to orignating room. There are no fire walls, separations, or smoke separations involved.
I have looked through ASHRAE but have found no clear example, most quote exhaust fans for kitchens, bathrooms etc.
Another project just has a straight fan installed in wall of office, drawing in cooler air from main office. Is this allowed?
Any info on allowed usage of transfer fans would be appreciated.
RE: Transfer fans usage in commercial bldg
Transfer fans are quite common here in Los Angeles, especially under Tenant Improvement work taht involves with break rooms and dining areas. We normally use a transfer boots when its from room to room.
I dont know if that made any sense....
By placing a fan in the airstream, you will be adding heat to the air, lowering the cooling capacity. Transfer grilles and ducts are common for return air applications in a ceiling plenum, because the air is warm and you do not have to worry about the throw of the air from a register. It would seem to be allowed, just cheap. These types of wall fans are usually relegated to machine rooms. I recall an elevator machine room that had a thru-wall exhaust fan to the outside and a fire rated louver in the door to pull air from the hallway.
Try to duct it directly, sheet metal isn't as expensive as it was last year.
Dan
