power factor correction
Does anyone know of a cost effective method other than capacitors for power factor correction on small 480 volt distribution system <6300 kva? Capacitor purchase and install too costly for this installation.
RE: power factor correction
Gunnar Englund
www.gke.org
if you have own generators, put it on PF compensation mode. It will automatically maintain the P.F.
Try to maintain P.F at load end, Not on PCC or main bus.
Anuj
Margaret
What is the PF and load in KVA now? What is the demand charges (usually about $5/KVA per month)?
