1045 Annealed VS Hardened and tempered
In one of our applications a 0.188 thick round washer skipped the heat treat process. It is a 1045 annealed, then stamped, then water quenched to acheive 40Rc and tempered. A few samples however were used just in the annealed condition. This washer is used to preload an input pinion bearing in a marine sterndrive and is sandwiched between the bearing inner race and u-joint bearing face. It will see forces in the axial direction.
I was wondering how the annealed washer would behave differently in comparision to the hardened washer? Any thoughts on its deflection/yeilding?
RE: 1045 Annealed VS Hardened and tempered
