Import Macromedia Freehand Paths To Inventor 10
Yes I know that Macromedia Freehand is not for designing mechanical devices but it was all I had at the time.  Anyway I have 2D mechanical style line drawings for a device that I drew up in Freehand MX and I need to take all of the paths from Freehand and somehow import them into Inventor 10 as a sketch so I can make them into parts.  The only thing I can do so far is export the Freehand files to Adobe Illustrator and then export them from Illustrator to .DXF or DWG. files which I can then open in Inventor. So I'm sitting here looking at Inventor with my imported drawing on the screen as a sketch.  But Inventor does not recognize the imported path correctly.  It thinks it is not closed or something.  So when I try to close it or move any of the points all of the curves on the path become distorted. If I try to change the points handle type Inventor crashes.
Does anyone know a better way to go from Freehand paths to Inventor sketch?
Thank you -
