Sulfatreat Vessel and KO drum - Appx weight and dimensions
Please, advise me with approximate weight and dimensions for:
1) Sulfatreat Vessel - pressure vessel
Capacity 2m3
design Pressure 340 kPa
2) Flare Nock Out Drum
Capacity 5m3
design Pressure 1965 kPa
RE: Sulfatreat Vessel and KO drum - Appx weight and dimensions
First off go back to your process group and get physical sizes. Then you can calculate your thicknesses and determine weights. Carbon steel is 7850 kg/m3.
