temperature rise of fluid due to pipe friction
What fomula could be used to detemine the temperature rise of a liquid due to the pipe friction?
have a nice day
RE: temperature rise of fluid due to pipe friction
Do an energy ballance!
The energy lost to friction must be turned into heat - this heat is on the other side exchange with the surroundsings.
Best regards
Morten
I cannot recall the equation off hand, but I do remember getting one from Perry's Chemical Engineering Handbook; 6th edition a couple years ago.
ChemE, M.E. EIT
"The only constant in life is change." -Bruce Lee
Assuming you know pressure in and pressure out; it then becomes a simple thermodynamics problem.  Take the pipe as the free-body diagram.  You could assume adiabatic conditions and solve for outlet temperature or assume constant temperature and solve for heat out.
h= spec. enthalpy
v= spec. volume
p=pressure
u=velocity
F=friction,  (f/d)u^2/2
s spec. entropy
T=abs. temp
Q=heat transfer
x=distance
T(ds/dx)=  uF+Q
dh/dx-vdpdx=uF+Q
Cp=spec heat at const press.
for Adiabatic conditions and v approx constant
Cp(Delta T)-v(Delta p)=uF(pipe length)
Knowing pressure drop, spec. heat,spec. vol, velocity and friction factor, --Solve for Temp difference.
If the mu, the J-T coef is available my last post could be modified for andiabatic and highly incompressible flow as follows:
energy equations dh+du^2/2=0
 highly incomp flow yields  approximation of dh=0    perfect for use of J-T
dh/dx-vdpdx=uF+Q
 dh/dx-vdpdx=uF  adiabatic
  -vdpdx=uF         for dh=0
-v(dp/dT)dT/dx=uF
-v/mu(dT/dx)=uF
delta temp=   -(mu)(uF/v)*length of pipe
Comments please!
Pump bhp = GPM x Ft Head /(3960 x Pump Eff)
With motor out, driven equipment in, heat gain Btu/hr Q = bhp x 2545 = gpm x 500 x (°F Td)
