Bronze or brass labyrinth seals
Dear forum members:
I am trying to replace some worn and deformed brass O-rings mounted on a generator shaft.
These O-rings form a labyrinth seal which keeps the oil inside the bearing housing.
The bronze seals are installed in several grooves machined on the shaft and retained with a caulking wire or fastening ring.
Could anybody please give the name of a manufacturer?
RE: Bronze or brass labyrinth seals
