Air motor tachometer
I am designing a unit with an adjustable speed air motor (Gast 4AM). I need a tachometer, only mechanical (no electric on the unit.
Gast doesn't make an add-on, but I have seen them on other units.
The tachs I have seen replaced the idle side bearing cover with the tachometer.
Any ideas where I could find an aftermarket part for these?
RE: Air motor tachometer
Google for mechanical tachometer returns 149,000 hits.
I bet one has just what you need.
