composite floor deck on ribbed concrete
Anyone come across a condition where a concrete composite deck is placed on top of an existing ribbed concrete deck? The corrugated composite deck wil span perpendicular to the concrete ribs (one way joists). The existing slab between the ribs is a little less than 3" in some areas and the new deck is to be for observation. I was hoping to use the composite deck to increase the effective depth of the reinforcement and strengthen the floor systems. The composite deck will be made of lightweight concrete and only 3-1/2" thick. The existing deck spans 19' and has 6" ribbed slabs at 36" on center with a pan depth of 8" and slab of 3". Calculations of additional deck and live load superimposed are good for shear and flex. Do I need a special connection for shear transfer to the deck? Any one with experience using this type of application? Would a cellular type deck be better?
RE: composite floor deck on ribbed concrete
DaveAtkins
