Metric Cable Derating
Does IEC 287 or other IEC standards require derating Direct Buried 3/c Medium Voltage Cable based on thermal conductivity?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Metric Cable Derating
Could you elaborate how the derating is calculated? Is the Neher-McGrath method used?
The main differences in both methods are the units system used (English vs. SI/metric). Also the IEC method includes new developments of cable laying, configuration and drying soil effect due to heating by loaded power cable. Another standard, IEC 853-1 & 2 supplement IEC-287 covering cyclic load and emergency ratings.
See the enclose links for information regarding thermal resistance consideration in IEC 287.
http://www
http://www.elect.mrt.ac.lk/IEE2002powercables.pdf
Thanks a lot. That's just what I needed.
