Structure library
Structure library
Structure library
I wanted to go in and edit some aspects of my structure library, but I don't know where it is located. Can someone tell where, and if it feasable to edit certain things?
Thanks.
BTW, it's LDD 2005.
RE: Structure library
I am sorry but I do not know what the Structure Library is. Is is called anything else in AutoCAD or do you have a certain version of AutoCAD?
"Everybody is ignorant, only on different subjects." — Will Rogers
I am referring to the pipes structures, i.e. manholes, basins, etc. for drawing pipe profiles. The people at my firm have been shading the structures, so I wanted to look into having the program draw a single polyline of specified width, to bypass the shading/hatching process.
if you send me a screen shot of what you want to amend from your AutoCAD I may be able to help. awol@fsmail.net
