Gas consumption curve for 10MVA Gas Turbine Generators
Hi all,
I'm trying to do a justification for building a new power plant and need to do a TCO comparison between the existing plant a new one.
To do this, i need to have a curve that shows the gas consumption at different loads for a 10MVA gas generator, specifically a Solar Mars 100. Alternatively, I could use discrete values at different loads.
Any information on this will be much appreciated.
xchnauzer.
xchnauzer.
RE: Gas consumption curve for 10MVA Gas Turbine Generators
But there is only a 100% curve in the brochure you can download.
Best regards
Morten
good luck!
-pmover
