Sewing machine motor
Does anyone know how to reverse the rotation on a 115v AC sewing machine motor?
RE: Sewing machine motor
This is just a guess on my part.  Others here will know 4-sure.
Sometimes there is a way to adjust where the brushes sit on the commutator.  I believe you can change the direction by slightly moving the timing set by the brush location.
Not only adjust - move 180 el degrees. That is easiest achieved by switching polarity of armature or field. Just switch wires going to either.
Gunnar Englund
www.gke.org
Thanks for that clarification skogs.
