references for mixer scale-up?
I'm looking for any good references or rules-of-thumb for mixer scale up. Are there any rules of thumb for power input required to produce similar mixing intensity in vessles of larger sizes? Apart from being a function of viscosity, etc, is there a simple relationship between power input, assuming similar tank design with respect to baffles and geometry. I know it is very difficult to get uniform mixing in tanks of larger size, but could someone shed some light on the physics behind this?
RE: references for mixer scale-up?
Fran McConville
m777182
http://www.lightnin-mixers.com/cs_techinfo.asp
Click on Technical Articles
Good luck,
Latexman
You have gotten very good advice so far. I have read the articles from Chemineer and they are good. Fxm is right in that if you have similar geometry then you can look at W/kg as a rough guide to scale up. (I generally use 5HP/500gallons. But we use very violent mixing.)
A good book that I have on mixing called Mixing for the process industries Robert J. McDonough.
If you come back with a little more details we can give you a rough idea.
