Removing bend lines from dxf
Hi
When I want to send a sheet metal part to lasercutting usually I go in "draw in view" of my flat and I select save as dxf. Until V17 there wasn't any bend lines in the dxf but now the bend lines are translated with the dxf and I don't know how to erase it without having to go into the dxf with autocad.
I tried to hide the bend lines before saving as but it still translates the bend lines into the dxf
Any ideas?
Patrick
Any ideas?
Patrick
RE: Removing bend lines from dxf
I don't know how you hid them, but if you open the Drawing Views properties form and click on the Annotation tab, you will find a checkbox to turn off the bend centerlines. You can then save the DXF out without the bend centerlines.
Ken
That's exactly how I did it and what I tought would be the solution but as I said this doesn't work anymore with V17.
Patrick
You have a hide edges tool that might help you.
Otherwise, why don't you try with the 'save as flat' command from the sheet metal environment ?
May be you should wait a little bit though b/c I created an IR about problem with the save as flat dxf export options and received a resolution letter saying it was going to be fixed in the update 4.
Fred
