Does Window XP Service pack 2 affects WF2?
Hi all,
Our IT dept just installed window xp service pack 2 on my pc and i find that WF2 is running slower than usual. A simple model is even rotating slower than it used to. Will this problem has anything to do with SP2? Has anyone has a similar problem before?
Thanks!
RE: Does Window XP Service pack 2 affects WF2?
If I'm not mistaken the XP SP2.0 has the firewall which is defaulted to activate.  Maybe if you disengage this things will get better.  I'm running Pro/e 2001 and didn't notice any differences but I disengaged it anyway.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
Thanks Heckler! I've found a fix to the problem. It was a graphics issue rather than a WF issue. I just had to update the driver for the graphic card and the problem is gone.
Thanks anyway!
-gwen
