Neutralization of Water Produced in Desalination Plant
Hi there!!
In a project of MEVC desalination plant, the water produced has a 6.5 - 7 PH.
To avoid corrosion in steel tubes, is a good idea put a NaOH injection system?
Bye
Bye
RE: Neutralization of Water Produced in Desalination Plant
If the water is for process use and low TDS is a requirement, adding caustic may not be suitable either. If you can mainitain the dissolved oxygen at less than 0.3 mg/L you may not have to do anything special.
I know there are a lots of "ifs" in my response but you will have to tell me more about your intended use of the water.
