sump pump problem
sump pump problem
Have a pedastal sump pump that no longer is pumping, bailed out water and when engaged the water shoots out the sides of the bottom of the pump. Cleaned around the sides of this but it didn't help. Just learned that there is a screen on the bottom, if it is clogged will it cause this problem. Thanks, hope that made sense.
RE: sump pump problem
