Moving part in assembly problem
Hi I have an assembly with some part and some other sub-assembly. My problem is, when I want to move part or sub-assembly or put contraint, Is't take a lot of time to get mouved. This is happen when I load a part from a catalog.
Is this a computer problem or a software problem. If i turn the CACHE ON or OFF, this is have no change....
I run on CATIA V5 r13 sp 4
thank !!
RE: Moving part in assembly problem
I can move parts and sub-assemblies easily even for huge assemblies. I think your computer (specially your graphic card maybe) has a problem.
Fabien
Is this the only time you experience this problem?
What happens when you load a part from somewhere other than the catalog?
YES IT'S HAPPEN ONLY WHEN I INSERT PART FROM CATALOGUE
