BOM & Lightweight Assy.
I searched the forum, but didn't find anything on my question.
I've noticed w/ several assemblies that if you create a BOM in a drawing while the model is lightweight, the BOM is all screwed up (like not calling out the right info for the properties selected to be in the BOM). As soon as the assembly is changed to resolved, the BOM is fine.
Just wondering if this is something SW is programmed to do (& if so, for what reason) or if it's a bug that anyone else has experienced?
RE: BOM & Lightweight Assy.
As far as I know this is normal. I have the same thing happening on my Assembly Drawings. Once the Drawing is resovled the BOM is ok. Not all the required information is there for the BOM to update because it is in Lightweight. Hope this helps.
Cheers,
Ralph
SW2006 may have addressed this "problem". Almost everything that can be done in a fully resolved drawing can be done in a lightweight one.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
