using dial lighting software
I am currently working on a house extension that is mostly glass. I have just started using dial and there is no-one in my employment that can use this software. What i want to do is either import the architects plan or another method. What exactly do you have to do change the walls to glass or if easier what do i do to import the arch plan?
Also do you know of a tutorial or other information that i should know to become proficient in dial?
RE: using dial lighting software
"Everybody is ignorant, only on different subjects." — Will Rogers
