conditional formatting of autoshapes
Is it possible to change the colour of an autoshape or fill of an autoshape, depending upon the value in another cell?
RE: conditional formatting of autoshapes
yes, but with limitations, which are:
1) accomplished using vba code.
2) value in cell is a valid color.
good luck!
-pmover
thank you Pmover.
unfortunately, just as I suspected.
You could always use Select Case in your macro - you can then use any values to set any colours
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
