evaluation of the max allow pressure
hi,
how can we determine the maximum allowable pressure of a stainless steel pipe whitout using the thickness, according to EN 13480-3 standard?
i know that we can evaluate it by a process engineer, but I want to know if we can use the data from an other process which is not enivitably complying with the conformity assessment.
thanks very much
bye
RE: evaluation of the max allow pressure
see my post in ASME Forum
abbver98
thank you very much for your invaluable help
