Photoworks materials are no longer grouped??
I'm finally working with 2005. in 2004, when I selected 5 surfaces and applied materials to them, all faces would be listed under one material, editing that material carried over to all of those faces. Now I open the file and each surface has an individual material, making it almost impossible to edit. is there some way to fix that?
"we all come into the world the same way, naked, screaming and covered in blood. If you live right, that kind of thing doesn't have to stop there!"
RE: Photoworks materials are no longer grouped??
You could try right clicking and using the "attach to selction" option to consolidate your materials? Might work as a way around the problem but you should really find out what is causing this.
Rob Rodriguez CSWP
www.robrodriguez.com
SW 2005 SP4.0/SW 2006 EV
