Pump for Chromatography system
Can anyone give more information about the chromatography pumps.
I am intending these pumps for IonExchange chromatography. Small scale and medium scale.
Colimn dia around 1.1 cm to 3 cm
Linear flow rate around: 300 cm/h
Thanks a lot in advance.
RE: Pump for Chromatography system
helo sir , i like to know about the function.so please sent details to my id.thank you
Hi there!
The application for this pump  is to provide a non pulsating flow. The pump will be used to pack the colum and to purify the protein.
As I mentioned it should be able to run at 300 cm/h
The column dimensions are given to convert ml/min flowrate. Normally it comes to 2 - 10 ml/min flow rates!
I hope this helps!  I do not have your email ID so really can't send a direct email to you!
Thanks for your response.
