Volume Loss in Gravel Processing
I'm working on a project where we need to reduce the fines content of a stockpile of owner-supplied material. I'm looking for some advice in determining how much volume will be lost to processing gravel through a vibrating screen. For example, if I start with a 1000 cy pile of 2" minus material, and a grading report shows that 20% passes through a 3/4" screen, if I run the pile through a 3/4" vibrating screen, will I end up with 800 cy of 2" minus?
RE: Volume Loss in Gravel Processing
All of this will depend on the type of rock, actual gradation, handling, etc.
Hope this helps.
