assembly sequence video
I would like to output a video file from an assembly sequence so others that don't have access to UG can see it. However, there doesn't seem to be an option to export it out to any video file format (avi would be great).
Is there an option there that I missed? Anyone have a suggestion for a different way to do it? Maybe a third party screen capture type application? Hints, tips and suggestions are all welcome.
RE: assembly sequence video
I am in the same boat (driving NX3) and would like a solution. Have you you found a solution?
Can anyone suggest an output solution?
Seems strange that having spent time creating an assembly sequence you are left with no obvious output route?
www.bobyte.com
Works ok if you use the Microsoft MPEG-4 Video Codec
Mark Benson
CAD Support Engineer
www.techsmith.com/products/studio/default.asp
Works really nice
Omar
Take care...
Take care...
Take care....
