MORPHOLINE & 2-DIETHYLAMINOETNANOL
Dear All,
The above mentioned chemicals are a part of the complex water treatment chemical. Can you please advise on the specific action of each one - e.g. corrosion inhibition and oxygen removing etc?
Thank you,
Jeyx
RE: MORPHOLINE & 2-DIETHYLAMINOETNANOL
Both chemicals are used for chemical treatment of the steam/condensate to reduce corrosion.
use google : Morpholine steam application
rgs
Yes, that's ! Morpholine is used as a vaporizer.
