preloading stress in a Harmonic Analysis
It seems that when I run a harmonic analysis the magnitude all of my applied forces including gravity are based on a sin function. I am fine with this for gravity, because I am essentially performing a vibrational analysis at a set frequency using gravity as my vib load. My applied (nodal)force, on the other hand, actually simulates preloading of the part which should be constant through out the analysis. Is anyone familiar with how to select some forces to be static and some foces to be harmonic in a harmonic analysis. I guess that I could do a dynamic analysis, write a constant function for my preloading force, and write a sinusoidal function for the gravity load, however this would only allow me to view results at a given frequency. An entire defined frequency spectrum of results would be obtainable through an harmonic analysis.
proEdj
sorry for being wordy
proEdj
RE: preloading stress in a Harmonic Analysis
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
Cheers
Greg Locock
