Insert a block based on anothers attrib insertion
ok where would i start lsp wise to make a lisp that given a block and either the contents of or tag name of an Attribute would insert said block at that attributes insertion point??
any ideas of where to start or how to go about getting the attributes insertion point with out exploding the block
if everyone helps everybody the world will be a better place
RE: Insert a block based on anothers attrib insertion
To access an attribute attached to a block, you must first find the block, extract the entity name of the block, step up to the next entity following the block (entnext blk_name)
This should be the attribute entity name, then entget the list i.e.
(entget att_name)
Now you can look at the dxf group codes 1,2,3,10 & 11
If the group codes of 1,2 & 3 match the attribute you are looking for, then use the dxf code 10 for the insertion point of the new block. If the attribute is a justified entity (other than left justify) then use the dxf code 11 for the insertion point.
So...
(defun C:InsertAtAtt( / att_list )
 (setq att_name (entnext (car (entsel))))
 (while (not att_list)
  (setq att_list (entget att_name))
  (setq tag (cdr (assoc 1  att_list))
        val (cdr (assoc 2  att_list))
        prm (cdr (assoc 3  att_list))
        a10 (cdr (assoc 10 att_list))
        a11 (cdr (assoc 11 att_list))
  (if (and (= tag "this_value")
           (= val "this_value")
           (= prm "this_value")
       (command "_.insert" "block_name" a10 "" "" "")
       (setq att_list nil)
Will the attributes settings make a diference i mean like what if the case is that the attribute is set to constant and invisible
If the attribute is constant and invisible, then the attribute is treated as an entity in the block rather than an attached entity. The above code won't work with that scenario.
So what can i do can i tell it to look for specifically invisible constant attribs the main reason i have them as such is i dont want them seen or printed but they may need to be extractable later
You can make the attribs invisible and still access them from the above code, however once you make them constant, they are treated much like text in a block and you cannot access them using the code I provided above. I suggest making the arribs invisible but not constant, however you will have to answer the prompt when you insert the block.
If you read the block definition from the block symbol table then filter out the entities until you find the invisible/constant attribute, then apply the coordinate of that attribute to the insertion point of that block (adding the X to X, Y to Y, and Z to Z) and rotation of the insert, then you can extrapolate the position of the constant attribute and hence insert another block at that position.
ok well striker what if the blocks are not just blocks by them selves what if they are an AEC_MVBLOCK_REF which are the multiview block created in ADT but i want to be able to access both... by the way im using ADT 3.3
can i do a ssget and filter by object type/name???
im confusing myself maybe u can clairify all im wanting is to give the name of the block or by selecting one then have it look at the attribs and use a specific attrib tag/value/prompt use that attribs insert pnt does this make sence to you
i have been trying to get a good example of the ssget x deal so that it makes a selection set of all the blocks and allow me to filter by name of block or am i going the wrong way
???Which is the easiest, fastest, least difficult???
OK, lets see if we can take this one step at a time.....
The blocks are multiview blocks created in ADT... they still should be accessable through the block definition table. You can then still step through the definition to get the attribute insertion point if in fact it is invisible and constant. I would still recommend changing to invisible but non constant ... it seems easier that way.
To select all objects in the drawing based on specific criteria it is preferable to use the ssget "x" function call. The correct syntax for using ssget "x" is as follows:
Create a list of entity data (excluding xdata) that you want to filter by i.e. entity name, text value, entity type, layer, color etc....
for example:
(setq filter_list (list (cons 0 "TEXT")(cons 8 "LAYER1")))
You can specify any of the group codes if you know the value you are looking for and the DXF group code.
Now you can apply that filter to a selection set of all the entities in the drawing as follows:
(setq selection_set (ssget "x" filter_list))
You can also just quote the list in the ssget function as well:
(setq selection_set (ssget "x" '((0 . "TEXT")(8 . "LAYER1"))))
Case is insensitive for groups 0 and 8, but you must specify exactly groups 1,2,3 & 4
This will return a selection set of all entities in current space that are text entities on layer1
Keep in mind that (ssget "x" '((0 . "ATTRIB"))) will return nil regardless of the number of attributes in the drawing since the attributes are actually considered part of the complex insert to which they are attached, similar to the way a vertice is appended to a polyline entity. To access entities you must entnext the "parent" complex entity to retrieve the attached attributes excepting constant attributes of course.
I hope this sheds a bit more light on the subject
Yea i got one line of code no error
(Setq blknms (ssget "X"'(0. "AEC_MVBLOCK_REF")(0. "BLOCK REFERENCE"))
bout time i say
ok so this collects the names of the AEC_MVBLOCK_REF & BLOCK REFERENCE so u were saying that i need to use entnext to step thru and get the attrib stuff ok so do i start a new line and call out the variable or how do i do it let me give it a shot on what i should do
      (setq blkatt (entget (entnext (entnext (ssget ":E" '(2 . "ATTRIB"))blknms))))
(setq att_name (entnext (car (entsel))));Variable ATT_NAME that returnes the name of entities in the list of objects selected
 (while (not att_list); continues searching untill ATT_NAME Variable Is done collecting names
  (setq att_list (entget att_name));Variable ATT_list
  (setq tag (cdr (assoc 1  att_list));Variable TAG
        val (cdr (assoc 2  att_list));Variable VAL
        prm (cdr (assoc 3  att_list));Variable PRM
        a10 (cdr (assoc 10 att_list));Variable A10
        a11 (cdr (assoc 11 att_list));Variable A11
       (setq att_list nil)
Does that look about right i thought that maybe i could still use the bit of code u gave me and incorperate it i think i might have quite a fe mistakes but this was just a stab at it ya know
I am not sure if the code you have edited will return the constant attribute, I don't believe it will and I am not where I can test it. You can read the block definition from the block table by retrieving the block name (dxf -1) from the symbol table ...
(setq blkname (cdr (assoc -1 (tblsearch "block" "AEC_MVBLOCK_REF")))
Then you can entnext the variable blkname until you retrieve the desired entity (presumably a constant hidden attribute)
Hmmm well uhh im lost here is what i have snd im not sure that it is doing anything at all
(Defun C:InsertATATT ( / blknames blkatt blkattdef att_name att_list)
(setq blkname (cdr (assoc -1 (tblsearch "block" "AEC_MVBLOCK_REF"))))
(setq att_name (entnext (car (blkname))));Variable ATT_NAME that returnes the name of entities in the list of objects selected
       (setq att_list nil)
does not ask for input like block name attrib tag nothing well let me know where im going wrong or what direction i nee to go hey also take a look at the other post i did on lsp defaults i didnt understand quite what he was talking about something about variables that dont destroy??? i dunno maybe you can elaborate for me
Hey found this in an old lisp library and it deals alot with attribs thought the code might be usefull
;                           Michael Weaver
;                              Alascad
;                          1073 Badger Road
;                      Fairbanks, Alaska 99705
;                  Email:mikeweaver_ak@hotmail.com
;                    Voice and fax (907)488-3577
;                (c)1996, 1997, 1998 Michael Weaver
;                         Revision History
;        3/2/92        Added c:repatt function.
;       10/8/92        Added c:ate and c:atm functions
;       5/30/98           Added c:athm function
;    8/3/98         Added c:attpresuf
;ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ
;              (REPATT)  REPlace ATTributes globally
;   Environment:  autocad release 10 or later
;   Function: repatt
;   Purpose:  Repatt will search for all occurrances of a given block
;             and search all attributes within those blocks for a
;             given attribute value and replace each occurance with a
;             new a specified value.
;   Syntax:   (repatt block old new)
;             Where the arguments have the following values
;                 block     the name of the block to search
;                 old       the attribute value to be replaced
;                 new       the new attribute value
;   Included functions   block to act on    old string    new string
;       c:nodash          prompts user         -           <null>
;       c:repatt          prompts user     prompts user   prompts user
;       c:atem            select a sample attribute, select subject blocks
;                         specify the new attribute value.
;    c:attpresuf      add a prefix and/or suffixe to multiple attributes
;;;ÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ
(defun repatt (                ;REPLACE ATTRIBUTES GLOBALLY
           block            ;name of block to scan
           old            ;old attribute value to search for
           new            ;new attribute value
           /            ;end of formal argument list
           ss1            ;selection set of blocks
           indx1            ;index to ss1 for current block
           ent            ;entity name for current block
           elist            ;entity list for current block
           ent1            ;entity name for current sub-entity
           attflag            ;attributes follow flag for current block
           elist1            ;entity list for current sub-entity
           etype1            ;entity type for current sub-entity
           current            ;attribute value for current attribute
)                    ;end of local variable list
  (setq ss1 (ssget "x" (list (cons 2 block))))
  (if ss1
    (progn
      (setq indx1 -1)
      (while (< (setq indx1 (1+ indx1)) (sslength ss1))
                    ;while blocks in selection set
    (setq
      ent      (ssname ss1 indx1)
      ent1      ent
      elist      (entget ent)
      attflag (if (assoc 66 elist)
            T
            nil
          ) ;_ end of if
    ) ;_ end of setq
    (if attflag
      (progn            ;block has attributes
        (setq
          ent1   (entnext ent1)
          elist1 (entget ent1)
          etype1 (cdr (assoc 0 elist1))
        ) ;_ end of setq
        (while (/= etype1 "SEQEND")
          (if (= etype1 "ATTRIB")
        (progn
          (setq current (cdr (assoc 1 elist1)))
          (if (= current old)
            (progn
              (setq elist1 (subst (cons 1 new)
                      (assoc 1 elist1)
                      elist1
                   ) ;_ end of subst
              ) ;_ end of setq
              (entmod elist1)
            )            ;end progn
          )            ;end if current = old?
        )            ;end progn entity is attrib
          )                ;end if entity type?
          (setq
        ent1   (entnext ent1)
          ) ;_ end of setq
        )                ;end while not seqend
        (entupd ent)
      )                ;end progn block has attributes
    )                ;end if attributes?
      )                    ;end while not end of ss1
    )                    ;end progn blocks exist
  )                    ;end if blocks exist?
)                    ;end of repatt
                    ;RELEASE 10 OR LATER
(defun c:nodash    ()            ;DRIVES REPATT WITH - TO <NULL>
  (repatt
    (cdr
      (assoc
    (entget
      (car
        (entsel
          "\nSelect block to eliminate dash attributes: "
                    ;select block
        ) ;_ end of entsel
      ) ;_ end of car
    ) ;_ end of entget
      ) ;_ end of assoc
    ) ;_ end of cdr
    "-"                    ;old string
    ""                    ;new string
  ) ;_ end of repatt
) ;_ end of defun
                    ;Release 10 or later
(defun c:repatt    (            ;REPLACE ATTRIBS GLOBALLY, INTERACTIVE
  (repatt
    (cdr
      (assoc
    (entget
      (car
        (entsel
          "\nSelect block to replace attributes: " ;select block
        ) ;_ end of entsel
      ) ;_ end of car
    ) ;_ end of entget
      ) ;_ end of assoc
    ) ;_ end of cdr
    (progn
      (setq
    oldatt (if oldatt
         oldatt
           ) ;_ end of if
    test   (getstring T (strcat "\nOld attribute value<" oldatt ">:"))
    oldatt (if test
         test
         oldatt
           ) ;_ end of if
      ) ;_ end of setq
    ) ;_ end of progn
    (progn
      (setq
    newatt (if newatt
         newatt
           ) ;_ end of if
    test   (getstring T (strcat "\nNew attribute value<" newatt ">:"))
    newatt (if test
         test
         newatt
           ) ;_ end of if
      ) ;_ end of setq
    ) ;_ end of progn
  )                    ;end call to repatt
)                    ;end c:repatt
                    ;replaces the value of text and attribute entities with a given value
                    ;RELEASE 11 OR LATER
                    ;Mike Weaver  (907)344-7263  2/11/92
(defun attrep (                ;REPLACES VALUES OF SELECTED ATTRIBS
           value            ;new value for entity
           /            ;end of argument list
           ent            ;list returned by nentsel
           elist            ;entity list for current entity
           etype            ;entity type for current entity
  (while (setq ent (nentsel "\nSelect attribute: "))
    (setq
      elist (entget (car ent))
      etype (cdr (assoc 0 elist))
    ) ;_ end of setq
    (cond
      ((= "TEXT" etype)
       (princ "\nEntity selected was text. ")
       (setq elist (subst (cons 1 value) (assoc 1 elist) elist))
       (entmod elist)
      )                    ;end cond TEXT
      ((= "ATTRIB" etype)
       (princ "\nEntity selected was an attribute. ")
       (entmod elist)
      )                    ;end cond ATTRIB
      (T
       (princ "\nEntity selected not text or an attribute. ")
      )                    ;end cond not valid
    )                    ;end cond etype?
  )                    ;end while
  (if elist
    (entupd (cdr (assoc -1 elist)))
  ) ;_ end of if
)                    ;end attrep
(defun c:null ()            ;DRIVES ATTREP WITH <NULL>
  (attrep "")
  (princ)
) ;_ end of defun
                    ;;;c:adt takes selected text and/or attribute entities and combines their
                    ;;;values adding a space and applies the result to the first entity
                    ;;;selected.
                    ;;;c:adtx works similarly to c:adt except all entities after the first are
                    ;;;erased and there is no space added between the entities.
                    ;;;adt is the engine driven by c:adt and c:adtx.  It's syntax is as follows.
                    ;;;(adt spacemode erasemode)
                    ;;;Where the arguments have the following meanings:
                    ;;;spacemode           if non-nil a space is added between text values.
                    ;;;erasemode           if non-nil subsequent entities are erased.
(defun c:adt ()                ;adds text values with a space, doesn't erase anything
  (adt T nil)
) ;_ end of defun
(defun c:adtx ()            ;adds text values without a space, erases subseqent entities
  (adt nil T)
) ;_ end of defun
(defun adt (                ;COMBINES TEXT/ATTRIBUTE VALUES
        spacemode            ;add intermediate space if non-nil
        erasemode            ;erase all but 1st item if non-nil
        valid            ;local function
        ent1            ;primary entity
        ent2            ;secondary entity
        elist1            ;entity list for ent1
        elist2            ;entity list for ent2
        test            ;loop control flag
        *error*            ;internal error handler
        undo            ;undo control flag
                    ;;;ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
;;LCA - COMMENT: *error* defun no longer evaluates as a list.
  (defun *error* (st)
    (if    undo
      (progn
    (setvar "cmdecho" 0)
    (command "undo" "e")
    (setvar "cmdecho" 1)
    (setq undo nil)
      ) ;_ end of progn
    ) ;_ end of if
    (if    ent1
      (redraw (car ent1))
    ) ;_ end of if
    (princ st)
    (princ)
  ) ;_ end of defun
  (defun valid (elist)            ;VALIDATES ENTITY TYPES
    (if    (or
      (= (cdr (assoc 0 elist)) "TEXT")
      (= (cdr (assoc 0 elist)) "ATTRIB")
    )                ;end or
      T                    ;return T
      nil
    )                    ;end if
  )                    ;end valid
  (command "undo" "m")
  (setq undo T)
  (setq ent1 (nentsel "\nSelect primary entity: "))
  (if ent1
    (progn
      (redraw (car ent1) 3)
      (setq
    elist1 (entget (car ent1))
      ) ;_ end of setq
      (if (valid elist1)
    (progn
      (setq test T)
      (while test
        (setq
          ent2   (nentsel (strcat "\n"
                      "\nSelect entity to combine: "
                  ) ;_ end of strcat
             ) ;_ end of nentsel
          elist2 (if ent2
               (entget (car ent2))
             ) ;_ end of if
        ) ;_ end of setq
        (if    (and elist2 (valid elist2))
          (progn
