Drive expression by component name?
In an assembly, is it possible to drive an expression based on what a certain component name is?
Basically I use an expression to control a mate dimension. I want to change the value automatically based on which family component is inserted. So:
if component="Liner, 32mm", then mate dimension = 1, etc...
Jason
RE: Drive expression by component name?
I think it would be easier to have an expression that controls the configuration ie configuration=1
Then have conditional expressions for the mating distance based on the value of "configuration".
You may also have component suppression expressions that are conditional based on the "configuration" expression.
Jonathan T. Schmidt
http://www.schmidtmotorworks.com
Jason
the suppression by expression can be found in the Assembly menu. The syntax for conditional expressions is a bit strange and should be something like: if(<condition>) then <param>=<value>. I don't remember it exactly now, but I've got a Design Visionaries book which explains it. If you're stil interested in that topic, I'll have a look and post it there.
What I can't find is how UG distinguishes different instances of a component in the tree. Like if I insert a file "Bolt" twice, but I only want to suppress one of them by an expression. They both have the exact same name in the tree. Solidworks shows an instance number so you can tell the difference between multiple instances of the same part in your assy. UG has to have something similar.
Jason
I'm sorry that I can't post anything useful right now, because I haven't got my book here, I'll be able to look into it only on Friday evening or Saturday.
I'm sure you can suppress by expression in some way, what I don't remember is if / how we can distinguish between several different istances.
I'll let you know as soon as possible.
Regards!
you're right, I mixed up some things. So, correct answers are:
1-Conditional expression: syntax is: param_name=if(condition)0 else 1
where "condition" is a statement such as dim_1<=20 and the values before and after "else" can be any values, of course, or even expressions. In this last case, syntax is:
param=if(condition) (expre_true) else (expr_false).
2-Suppress by Expression is related to features. The command is accessed from Edit/Feature/SbE. From th dialog, you then have to select the feature's element to which the conditional expression will be related (ex: the center of a hole). Then, go to Tools/Expressions and look for the new expression added which looks like "p(x)=1". Then add a "switch" parameter such as switch=if(L>=300)1 else 0. Then modify the expression for p(x) by giving p(x)=switch.
3-Expression inside assembly's parts: you have to enable "interpart operation". After that, a parameter expression related to a component has this syntax:
component_name::parameter_name=value_or_expression. In order to distinguish between instances, the way I know is to assign a slightly different name to each.
4-I fear that in order to create several assemblies with different suspended/unsuspended components, you can't command this through the expr editor but you have to use Contexts. In this, I was too optimistic when I said that you could suspend a COMPONENT by expression... Please note anyway that I have very little experience with assemblies in UG. Also, I fear the conditional expression based upon the component NAME doesn't work: as far as I know there is no explicit function in the expr editor to recall the internal database field "comp_name".
Sorry, I hope that the few above things can be useful anyway...
You can suppress a component by an expression by right clicking on the component you want to suppress in the "Assembly Navigator", and then choosing "Suppression". The dialog that will appear will you give you the option to suppress by expression.
Jason
I am using Unigrphics NX2 ,
Does this function exists in NX2?
Jason
